any diy masking on 16x9 projection screens
mr gothic
hi
anybody done anysort of diy masking for other ratios on their 16x9 projection screens
any pictures or tips how you have done the masking
thank you
IWC Dopplel
Moved to PJ screens :)
Just about to have something made :D
I will post pictures when installed. It will be removable alloy formed bars, that will remain in place until I watch a 1.85 format film then removed (hopefully singlehandedly and quickly) I will cover with a sticky backed velvet or Felt :smashin:
mr gothic
thank you
i will look forward to the pictures and method you use
cheers
gary
IWC Dopplel
thank you
cheers
gary
The drawings are all done, a price agreed and it should be ready Tuesday, can't wait. It should look very neat and provide accurate, totally rigid masking 5mm away from the screen. Looking for self adhesive black trim (I have used self adhesive felt before, ordered some self adhesive velveteen material, I hope it is close to the Carada black hole trim)
mr gothic
hi iwc
sounds really good and you have that big screen so all screen formats will look good and big sadly i can only go to a 92" screen size,ive not got the width to go true cinemascope only poormans version
looking forward to the result,have you seen the home cinemas on the us avs sites with cinemascope they are truely brilliant
cheers
gary
IWC Dopplel
hi iwc
cheers
gary
If I was a rich man I would buy the Carada Masquarade system, look awesome !
IWC Dopplel
Baggy
Established Member
If I was rich I'd buy the SMX ProMaskCurv because it CIH.
Johnny.G
Established Member
If i was rich i would buy the local Odeon screen 1. :thumbsup:
fortean
Established Member
Sony A84L/A80L BRAVIA XR OLED TV Review - COMPARED to LG C3, Samsung QD-OLED & LG G3
Back
