Ja55
I bought my 6vs amp and 6s cd player pretty much by accident by bidding on flea bay without actually looking into / knowing about them other than Cyrus makes good kit. I've been pleasantly surprised. I've had the kit about a year and thought about improving it so asked Cyrus support what my upgrade options would be with the 6vs but they said it can't be updated (which is confusing as I thought upgrading was the whole Cyrus thing).
So i'm thinking of upgrading to an 8 amp but there are several versions - 8, 8a, 8vs, 8vs2, 8x, 8xp, 8xpd
The differences aren't obvious, not sure of release order, which is better?
Also would it be better to go with an older pre amp and power amp combo?
Does adding psx-r really improve all the kit including cd players?
Would it be better to get older kit with psx-r?
I've seen several power amps - xpa, smart power, 6 power amp, 8 power amp but again differences aren't obvious. They all seem to be rated 50wpc.
I've also seen some straight line amplifiers and don't know where they fit into things?
Jas
Jas
