Any comments on B&W FPM series?
Discussion in 'Home Cinema Speakers' started by scanneb, Sep 4, 2004.
  1. scanneb
    scanneb
    Is anyone familiar with the B&W FPM series wall-maounted speakers? If so, how would you rate them for sound quality for general home cinema / music use?
    Any comments on alternative wall mounted speakers would be appreciated.
    Rest of system will Pioneer PDP434HDE screen, Pioneer DV868i DVD player, Sky+ and Pioneer VSX-AX5i receiver (haven't actually purchased the latter yet - still considering options - have been using Cyrus kit and Wilson Benesch speakers but they are being reallocated to a separate system).
  2. angelislington
    angelislington
    May 14, 2003
    1,548
    Kent
    +234
    Superb. They look great and sound awesome. Make sure you choose a good enough subwoofer and you will have an amazing system.
  3. scanneb
    scanneb
    Thanks - with that recommendation I'll try and get a dealer to arrange a demo.
  4. angelislington
    angelislington
    May 14, 2003
    1,548
    Kent
    +234
    Whereabouts in the country are you?
  5. scanneb
    scanneb
    I live in Milton Keynes. We are not particularly well served for specialists shops here, so most of my kit came from Audio-T in Oxford, although my Pioneer PDP434HDE plasma screen and Pioneer DV868Ai DVD player came from Sevenoaks in Bedford. Audio-T were the ones who pointed me towards the B&W speakers, but it's a time consuming exercise to get across to them, so I wanted to check other opinions before trying to get an audition arranged.
  6. scrapbook
    scrapbook
    Jan 12, 2002
    7,435
    +553
    have you seen the FPM series on a website at all apart from B&W?
  7. scanneb
    scanneb
    Nope - I had been thinking about the Kef 5005 or 9000 series, but dealer recommended the FPM in preference to either. Dealer claims to have done a number of very successful installations usign FPM4, but I haven't managed to find any reviews anywhere.
