Any clever ideas on how to bend flat cable?
Discussion in 'Cables & Switches' started by cipher99, Mar 21, 2005.
  1. cipher99
    cipher99
    I have just got a roll of IXOS 607 flat cable and started to lay it out. However I have noticed that I cannot bend the cable through 90 degrees (On its horizontal plane as its wide and flat). Any ideas on how to do this from the custom installers / DIY'ers. I can keep it straight for most of the run, but I do need to make one or two twists.... Any help is much appreciated.
  2. Reiner
    Reiner
    Jul 16, 2000
    3,315
    61
    Germany
    +13
    Fold it over to the required angle (unless it get's too thick then).
  3. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    There aren't any obvious ways to bend flat cable in that direction.
    If you carefully slit the middle of the cable in that section with a knife you'll be able to twist and fold it naturally but hopefully keep the overall width a bit narrower. :)
