Any Cinema Amps with DAB yet ?
Discussion in 'AV Receivers & Amplifiers' started by Nick_UK, Dec 5, 2004.
  1. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Cinema amps with RDS have been around for many years, but I've not come across any with DAB reception. Do such amps exist ?
  2. recruit
    recruit
    Sony were supposed to be bringing that feature out in the STR-DB 795 but it never materialised i have not seen any others with it yet but i am sure it is only a matter of time!
    John
  3. patr1ck
    patr1ck
    Jun 29, 2002
    247
    Manchester
    +26
    Just an observation but the data rates on radio on Sky are greater than or equal to those on DAB. In fact some of those on DAB are not particularly good!
    Pat
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    have cambridge audio done one? not yet.... i guess they will come eventually i am sure i have seen one.. Yamaha perhaps.....
  5. Mr Incredible
    Mr Incredible
    Dec 2, 2003
    22,974
    The Fylde Coast
    +11,925
    My £0.02......
    It's ironic that the basic design of the AV Amp is based upon the processing of digital signals to analogue, and yet the introduction of the DAB digital platform has failed to materialise at this time. It seems to me that the introduction of a digital tuner to utilise the already excellent DAC processors would be both a better and cheaper option that having an analogue tuner.
  6. recruit
    recruit
    I think the problem as well with the introduction of DAB is that the coverage is not too good or should i say unpredictable IMO, as i had a dedicated unit but it kept on dropping out which was a pain!
    When the signal was there the quality was superb but not reliable enough :( the only option i had was to mount an external arial which i was not willing to do.
    If you live in an area which has good coverage you should be ok though..
    John
  7. Jules
    Jules
    Oct 11, 2000
    5,095
    +768
    I've got a decent Sony DAB/FM tuner (ST-D777ES).
    DAB is awful and your best off sticking with FM.
    The data rate used is very low and it shows.
    I sometimes flick between the same station broadcast on both platforms, and I cannot recall ever preferring the DAB broadcast over FM.
    Not even the excellent DACs in my Denon K-AVCA1SE make up for it.
    IMO, you should forget DAB and get a good FM aerial.
  8. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    I agree, it does seem rather odd. My DAB reception used to be OK, until the Peterborough mast burned down :thumbsdow
  9. Tenex
    Tenex
    Mar 2, 2003
    7,631
    +1,066
    As has been mentioned satellite and Freeview data rates on DAB are higher so a feed from a Freeview box to an amp would be the best way to go, indeed I bought my Netgem for the optical out to feed DAB to the amp........ so why haven't I got a round tuit ;)
    Probably 'cos I'm not in the room long enough to listen to anything.... One day!
