Any cheap vertical wall mount DVD systems?
Discussion in 'Home Cinema Buying & Building' started by loz, Mar 11, 2005.
  1. loz
    loz
    Jun 4, 2001
    13,058
    +1,796
    Looking for a cheapish all in one that could be mounted flat on a wall
    "lifestyle" fashion :rolleyes:
    Any suggestions?
    There's plenty of cheap wall mounted audio systems out there, but can't say I have seen a DVD one.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
  3. loz
    loz
    Jun 4, 2001
    13,058
    +1,796
    just for the kitchen wall - so I am really after nothing fancy or expensive - just to go alongside a wall mounted LCD, so hopefully I can just plumb it all in the partition walls
    You have a strange perception of cheap :D
    Cheap rules out B&O :thumbsdow
    Or the Panasonic you referenced (also I want small wall mounted speakers)
    I meant like £100 cheap - just a supermarket set really.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
  5. loz
    loz
    Jun 4, 2001
    13,058
    +1,796
    Well actually it is a very large kitchen come breakfast room 20 ft long.
    But no, I wasn't too bothered about 5.1. I might just mount the front pair.
    Mainly the LCD is for watching TV, but I wanted something for playing music, and the occassional DVD - so it would replace the existing stereo
    PS note my edits above :)
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    to fill a 20ft room you need a BIG sound what i would suggest is geta wall mounted DVD player and hide a stereo AMP in a cupboard and run a couple of pairs of ceiling speakers
  7. loz
    loz
    Jun 4, 2001
    13,058
    +1,796
    Nah, I am not trying to fill the room with sound, its the kitchen, not the home cinema (I already have that covered).
    Just something cheap and cheerful. The speakers in the LCD TV are already loud enough.
    I mainly just wanted to dispenses of the current clutter and cables of a DVD player, and a separate stereo system, and put them in one box.
    Is there a wall mounted DVD player.
    Not like that one you linked to before, one that has the controls and DVD on the front, as opposed to the side as that would, and actually has a wall mounted fitting. AND cheap :)
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
  9. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    the JVC VS-DT 7R/JVC VS-DT 6R would be ideal if it was DVD player but CD only otherwise i am out of ideas..............
