Any cables i need to build this PC tonight?
Discussion in 'Desktop & Laptop Computers Forum' started by oreoboy13, May 21, 2004.
  1. oreoboy13
    oreoboy13
    This stuff is being delivered today;
    2 x Crucial 512 DDR400 PC3200 CL=3 Memory Module 46420 Invoiced
    1 x A7N8X-E Deluxe SKTA NVNorce2ST ATX 8xAGP Giga LAN, SATA, Firewire, 6 channel Audio, USB2 Dual chan. DDR +WiFi slot (up to DDR400) 58198 Invoiced
    1 x Nec 8x DVD Dual R/RW IDE BLACK Burner - OEM 58481 Invoiced
    1 x Ebuyer Internal 7 In 1 USB 2.0 Card Reader Black 60662 Invoiced
    1 x Used Ag Neovo F-419 Black 19ins Tft Analog And Dvi 61390 Invoiced
    1 x Super Flower SF-464T2-BK Rhythmic Black Atx Case With Side & Top Windows and Front Cathodes 55432 Invoiced
    1 x Sapphire Atlantis Radeon 9800 PRO 128 MB DDR 8x AGP DVi & TV-Out 47511 Invoiced
    1 x AMD Athlon XP3200 400FSB 512Cache Barton Retail Boxed Inc Heatsink & Fan with 3year Warranty 48376 Invoiced
    1 x Ebuyer Anti-static Wrist Band 60609 Invoiced
    1 x Ebuyer 145 Piece Computer Tool Kit
    300W SilenX PSU from kustomPC
    160Gb SATA Samsung HD from kustomPC
    I am would like to put this together tonight, however i dont know which cables i will need to complete it, any suggestions that i could buy during my lunch break would be great.
  2. Daftboy
    Daftboy
    Jan 8, 2004
    505
    +12
    As long as the case comes with an AC Cord, the PSU with ATA power connectors and the motherboard comes with ATA cables, you shouldn't need anything else.
  3. oreoboy13
    oreoboy13
    Thanks, i suppose i was kinda worried as the NEC DVD writer is OEM, and only a power cable came with the Samsung drive, but if they both come with the MOBO its np.
  4. Pack Dude
    Pack Dude
    Feb 6, 2002
    876
    Lost In Space
    +98
    Any motherboard i have bought has came with two IDE cables. Ive bought about three PSU's and each one has come with a power cord, sometimes not with a UK plug.
    Ive not bought any of the newer AMD CPU's but i guess the newer "Retail Boxed" ones come with some heatsink thermal compound.
    Good luck
