Question Any BR/UHD Players With Bluetooth/Wireless Remote?
Discussion in 'Blu-ray & DVD Players & Recorders' started by fredericmcc, Apr 25, 2016.
  1. fredericmcc
    fredericmcc
    Feb 20, 2006
    54
    +3
    Hi, can anyone suggest any players currently available which come with either a Bluetooth or other type of wireless remote, rather than Infrared?
    Unfortunately my player lives in a close fronted cabinet and our current player (Loewe paired with Loewe TV) is having issues so may need to go back. The Loewe works fully through HDMI control but concerned that this could be buggy with someone else's player.
    Hoping someone now supplies a player with BT remote as having to use IR blasters etc will be a bit of a pain.
  2. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,071
    +6,952
    Certain Panasonic players can use an android remote control app (see here).
    I would expect their new UHD player could be controlled by it - but you would need to double check.
  3. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,071
    +6,952
    There is also this
  4. fredericmcc
    fredericmcc
    Feb 20, 2006
    54
    +3
    Thanks Gav, looks like just the solution.
    If someone's tried this on the UB900 would be great to know if it works.
