Any Benefit in Getting a Sound Card ?
Discussion in 'AV Receivers & Amplifiers' started by SkyWalker1726, Feb 28, 2013.
  1. SkyWalker1726
    SkyWalker1726
    Sep 1, 2009
    10
    Hi Everyone ,
    i currently have a Denon AVR1912 + 7.1 Focal Connected to my PC Via HDMI to an 680GTX nvidia ( wich i use to play games , watch blurays and listen to music ) , what i wanted to know is that would i gain in sound quality by buying a Sound Card ( Creative ZxR is the card that i have in mind ) ?
    the idea came to me while i was @ a Friend house and he had his Creative X-Fi Titanium connected to a Z5500 Logitech Speaker System and the Sound Was Amazing ( Specially Price/Performance Wise ) and Much Crisper than mine . we also tried his onboard soundcard and and switched back to the X-fi and the difference in quality was Huge ...
    after some googling i found out that the sound that his Sound Card did output was ANALOG , and that his speaker set is analog too , and my system is Digital and that my AVR did not support Analog sound , and that if i wanted to connect a Sound card to my AVR i had to opt for the Optical port and a Sound-card woundn't do any good to a Digitall Output ...
    so would a Xonar or ZxR be of any help to me in getting a better sound quality ? is analog sound better than Digitall ?
    Any help or advice would be appreciated
  2. laup
    laup
    Feb 5, 2012
    59
    9
    Norwich, Norfolk
    I have a xonar and to be honest mate no different to the built in one on my mb :)
    If its a digital signal its just 1's and 0's down the line & makes no difference. Stick to optical if u can, its always my choice.
    With analogue you would have to get some good quality Interconnects or 3.5mm to phono
  3. SkyWalker1726
    SkyWalker1726
    Sep 1, 2009
    10
    so u mean that i can get 7.1 analog sound from a sound card and connect it to my 1912 ? if so how ?
    thx
  4. laup
    laup
    Feb 5, 2012
    59
    9
    Norwich, Norfolk
    use 3.5mm to phonos
  5. SkyWalker1726
    SkyWalker1726
    Sep 1, 2009
    10
    yes but where to plug them in the AVR , i only have LEFT and RIGHT ( DVD , BR , ... ) in inputs , no center or Rear options available ...
  6. laup
    laup
    Feb 5, 2012
    59
    9
    Norwich, Norfolk
    well u need an avr then that take 8 channel input or use optical
  7. SkyWalker1726
    SkyWalker1726
    Sep 1, 2009
    10
    any recommendation ? ( avr with 7.1 analog input ) ?
  8. laup
    laup
    Feb 5, 2012
    59
    9
    Norwich, Norfolk
    If u have digital out just use that mate
  9. Hillskill
    Hillskill
    Moderator/Games Reviewer
    Mar 10, 2005
    22,717
    Somewhere being wrong but staying strong
    +5,531
