Quantcast
Any android phones with normal slide out Phone keypad ?
jimbob19
Trying to drag the wife into the 21st century but she will not use a touchscreen only nor use a qwerty keypad , as she prefers to use normal phone keypad for texting :(
Are there any android phones around with a slide out phone keypad (not qwerty). The only ones I could find were lumigon but they don't seem to have ever made it out into the wild
guitarplayer16
I believe all if not most of them have qwerty keyboards (touch screen or physical).
Maybe if all she wants is to text and have a non-qwerty keypad, you should reconsider if she needs an Android smartphone.
douki
Some touch screen phones have the option to switch to a regular keypad, alternatively you can download regular keypad apps from the Android marketplace.
RobM
David DG's suggestion seems the most sensible compromise. There are many touchscreen keyboards that are in the style and layout of the traditional 'T9' candybar mobile keypad.
I can't think of any Android device that has a physical one though. Must it be Android? Would Symbian not be a possibility, as Nokia might have something suitable that has smartphone-like features in a traditional shell.
Now might be a good time to suggest if she wants a smartphone, she'll need to learn to love QWERTY or touchscreen keyboards at some stage...
