Any advice on repairing scratched ipod
Discussion in 'Headphones, Earphones & Portable Music' started by matt bellamy, Aug 29, 2005.
Tags:
  1. matt bellamy
    matt bellamy
    Jun 19, 2004
    230
    16
    hi,
    does anyone know of a way to "clean" fine scratches from the screen and metal back of an ipod. Something like a polish that will make the scratches dissapear or less noticeable.
  2. AntWolverhampto
    AntWolverhampto
    Ive used brasso and a soft cloth on mine....works a treat on removing scratches both sides, metal & glass. Other than that, have a look at the cleaning range on www.everythingipod.co.uk - they sell specific cleaning packs there, but in my experience, brasso's good & cheap enough...available at all good wilkos!
    Ps, can also recommend www.ipodlounge.com for answering all cleaning questions....quality stuff....
    best of luck mate!! :)
