Any 28" sets with prog scan ?
Discussion in 'General TV Discussions Forum' started by probedb, Sep 17, 2004.
  1. probedb
    probedb
    Aug 20, 2003
    2,654
    Sheffield
    +180
    Hi all,
    Looking for a new TV to replace my old Panasonic 28".
    Are there any 28" WS sets around that have prog scan ?
    Or any sets anyone would recommend ?
    Thanks in advance,
    Paul.
  2. bodyfodder
    bodyfodder
    Iv got a 28ZD26p NTSC Progressive (also has a built-in de-interlacing)
    Id only recommend this tv if u could arrange to see your exact set before you bought it. Iv had a couple and they have all suffered from poor geometry and a weired moire affect near the edges of the screen.
    Good luck
  3. Digiman
    Digiman
    Dec 17, 2003
    367
    +17
    The JVC hv-28d40 has it.
  4. probedb
    probedb
    Aug 20, 2003
    2,654
    Sheffield
    +180
    the jvc looks good...the tosh would be ok as i only have ntsc prog at the mo but prolly could upgrade the player :)
