Any 24 inch monitors with built in tv tuner
Discussion in 'Computer Peripherals & Consumables' started by dudesweet, Jan 24, 2008.
  1. dudesweet
    dudesweet
    May 29, 2006
    2,722
    68
    +44
    After searching I have only found 22 inch LG, Samsung or ASUS monitors.Really after a 24inch.
    Reason I need an inbuilt TV tuner is because there are 2 sky boxes, not in my room,and these have been wired up so that I receive the feed of both into my room through a single aerial input. Currently that is on my CRT, so I assume if I got a monitor with inbuilt TV tuner it would work fine.
    Otherwise, any other ideeas? I am not sure if a TV tuner on desktop would recognise BOTH inputs. Might be a stupid question, just not so sure if it would work as well/easily.
    I may settle for a 22inch Samsung as it will be used as a monitor more than a TV, but buying a PS3 soon and wouldn't mind getting full 1080p.
    Thanks:smashin:
