Streamer73
Established Member
I currently have an Anti Mode 8033C in my set up (dual PSA S1510, Y cable from 8033 to subs) and am wondering whether I’d see any benefit from upgrading to the Dual Core? Subs are in the front corners, equidistant to the MLP but the room is open to the left hand side which seems to ‘steer’ some of the bass to the right hand side - sounds great but can be a bit lopsided sometimes.
Would the Dual Mode be able to help here or give an improvement over my current 8033C? Receiver is a 6500H so has dual subwoofer outputs (summed I believe) and I think the AM does a better job than Sub EQ HT on the Denon - I disable Audyssey for music (so just the 8033 doing any EQ) and use Reference for movies.
Any advice appreciated!
