Anthony Gallo's
Discussion in 'Home Cinema Speakers' started by viewer, Dec 22, 2004.
  1. viewer
    viewer
    Sep 26, 2004
    91
    Originally Posted by MAW
    I know a man.... he's panasonic certified to dismantle and spray, if you want it silver. Your spec sounds like www.anthonygallo.co.uk they have enourmous WAF, mine has just told me to buy us 3 bronze ones for the rears. We have Sonance in walls for fronts, not in your face at all, but mine are in a 'media wall' bit of furniture. To put them in your wall unless it's a stud is a major undertaking. The 'full monty' of Gallos, due centre, a'diva fronts, micro surrounds and rears, and a MPS150 sub would be a monster system, £2200 list, but thats 7.1 and as I say, list. I'm sure someone would do a deal for the works for you. The speakers come in silver of course. Incidentally I'm just about to send some stuff for spraying...
    MAW
    Would I loose anything by using micros for the fronts rather than diva's as I would need them in matt black (her in doors wants matt black) and diva's don't appear to come in matt black. Notice that the due centre is also only available in black (not gloss). The decissions I have to make to satisfy "management" !!!!!!!!
  2. Techno
    Techno
    Nov 20, 2003
    312
    I use Micros all round and am well pleased. I did buy a Due to use as centre but to be honest I sent it back because I couldn't really notice any difference.
    The sub's important, I have a Mordaunt-Short sub and am well pleased with the results, a friend has 5 micros and the gallo sub and likewise he's very happy.
  3. viewer
    viewer
    Sep 26, 2004
    91
    So I could use a micro for the centre as well - is that correct
  4. Techno
    Techno
    Nov 20, 2003
    312
    Absolutely.
  5. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    In the beginning there was only the Micros and the A'Diva came along later
  6. viewer
    viewer
    Sep 26, 2004
    91
    Anyone know where I can pick up MATT BLACK A'DIVA's
  7. Yaka
    Yaka
    Dec 20, 2000
    1,740
    2
    63
    +130
    try www.signals.uk.com i am in the middle of installing me adivas, atm i only have 3 going to set up as L R an center ( got em realy cheap £280 for all 3)
    i got the wallflower stands for the 2 fronts from signals. they had scuff marks on but at £55 were cheaper than retial price
    btw whats an ideal sub for em? i got around £250 to spend on em and i have had no replys in the thread i posted in subwoofer forum
