Anthony Gallo Speakers?????
Discussion in 'Home Cinema Speakers' started by Blingtastic, Jan 13, 2005.
  1. Blingtastic
    Blingtastic
    Hi to you all,
    Need a bit of reasurrance here. I'm thinking of buying the Anthony Gallo Speakers for a home cinema set up alongside a Pioneer xde435 plasma and a Pioneer AX5 amp. Has anyone got them or heard them setup. I'm buying them blind and they pretty expensive.
  2. TopMeTom
    TopMeTom
    Sep 8, 2002
    8,331
    +261
    You should speak to hayes at av-sales as they do the A.Gallo,also read his comments on the canton cd1 thread on here.
  3. jason t
    jason t
    Mar 4, 2001
    1,707
    48
    kent
    +38
    or try the orbs very similar to the ag but much cheaper
    jason
  4. smallangryboy
    smallangryboy
    May 5, 2003
    1,940
    +73
    I agree with jason t. Seeing as though your buying blind anyway you may as well go with the Orbs. You'll pay a lot less that the Gallo's and from what I've heard they compare favourably.
    I can't comment on the Orbs, but I've heard the Adiva's and wasn't impressed for the money, but they are tiny speakers so don't expect trouser flapping volumes and a massive soundstage. That said they are OK for a lifestyle package.
