Anthony Gallo Due ???
Discussion in 'Home Cinema Speakers' started by philinman, Jan 12, 2004.
  1. philinman
    philinman
    Jul 6, 2002
    406
    shropshire
    +4
    Hi has any one used an Anthonty Gallo Due speaker as a center channel if so what do think does it give a good sound worth the £500 as i need a small center due to wall mounting my plasma i was looking at this speaker .
    My M5c is to big to go on the wall shame as i have only had it less than a year :hiya:
  2. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,905
    It is important that the centre channel and the two main speakers are similarily voiced and I would imagine that the voicing of the Mission and Gallo are completely different.
    Can you not put your existing centre speaker on a stand ?
  3. philinman
    philinman
    Jul 6, 2002
    406
    shropshire
    +4
    thats what i thought but the gallo have a better range than my mission does (m5c) and i thought it would better match than fs1s or eggs ect :confused: i think i might buy one and give it a whirl as you you cant get a better demo than in your own room with your own stuff :smashin: :clap
  4. philinman
    philinman
    Jul 6, 2002
    406
    shropshire
    +4
    What other small speakers are ther avaible that you can use for wall mounting i am not keen on the eggs or the fs1s .
    I am open to suggestions dont like the look the look of the blueroom pods . as the look also plays a part in what speaker the boss will allow me !!!:devil:
  5. Jeff
    Jeff
    Jul 13, 2000
    5,501
    Basingstoke
    +263
    The Gallos are very neutral, I had a Due centre working very well with very different sounding Celestion C series front L/R. Now I have Gallo A'diva front L/R speakers it does sound better, but the previous odd match didn't sound wrong or anything like that.
  6. philinman
    philinman
    Jul 6, 2002
    406
    shropshire
    +4
    How do you find the fronts are they good and what about using them for music do they have that bigger speaker sound i have ordered the due as a center and got it at a good price so i will give it go and see what happens
    Thanks for your reply :hiya:
  7. Jeff
    Jeff
    Jul 13, 2000
    5,501
    Basingstoke
    +263
    I really like the A'divas, they are mainly used for movies. I'm very happy with music performance, I just don't listen to music as much as I watch movies. You do need a good sub, I use a B&W ASW2500 with mine. I found sub integration was very easy and the gallos sound full range, i.e you can't tell bass is coming from the sub. Gallos need need to be run-in so don't do any critical listening until the have done at least 20-30 hours (ideally 50 or so).
  8. philinman
    philinman
    Jul 6, 2002
    406
    shropshire
    +4
    Cool thanks :smoke:
  9. philinman
    philinman
    Jul 6, 2002
    406
    shropshire
    +4
    No sorry i cant put iy on a stand as some builder has put a BL**DY fire place on my wall :thumbsdow
    I want it to go below my plasma when it arrives roll on the 19th :smashin:
