Anthony Gallo Due Speaker Stands and MS302
lunker
Hello,
I've been looking for some speaker stands for my Mordaunt Short Premier 302's.
I really like the look of these but I can't find what type of connector they use.
Does anyone know If I will be able to connect my 302's to these stands or what type of connector the stands use so I can look at bodging something.
Or even better suggest a speaker stand that looks like the Anthony Gallo but with the perfect connections and cheaper?:rotfl:
lunker
I've found a picture of the wall mounts without speakers on and they appear to have a threaded single bolt.
I assume the floor stands will be the same connection I just need to find out what diameter that bolt is.
lunker
I also emailed Anthony Gallo who I've now had a reply from.
Basically they say no the stand has been designed for the Due only so I would have to bodge the connection.
I can't find anyone local that supplies these stands for me to have a look at so it looks like it's a dead end.:(
LG CX 4K OLED TV Review: The best TV of 2020?
