Anthony16v
Apologies if this a dumb question but I'm not 100% clued up on this topic!
I've recently purchased a Node 2 to play my music off a hdd / stream radio etc.
Currently I'm using the supplied cable for the 'rca' audio outs to connect into the mrx510. My understanding is, this means I'm using the DAC within the Node2? If I were to use the 'Optical Out' from the Node2.. does this then mean the DAC within the Anthem is then being used??
If I've got that right, then does anyone know 'on paper' which should be the better more capable DAC?
Many Thanks
Many Thanks
