Molly
I currently having stability problems setting up the audio return channel to a Panasonic CX802b.
I have set up the following:
- HDMI cable from HDMI 2 on the TV (ARC) to the HDMI OUT on the Anthem (is this correct or should it be say HDMI 1 on the Amp?)
- Set the the Amp HDMI CEC: On
- Set the Amp HDMI ARC: On
- Set the Amp HDMI Audio: AVR+TV
- Set the Amp Main Video Input: HDMI 1
- Set the Amp Main Audio Input: Dig HDMI
- Sometimes I seem to be able to control the volume from the TV remote and sometimes it doesn't change - I can't work out a pattern when it does operate correctly
- When I switch off on the TV remote both the TV and Amp go into stand by but when I turn on via the remote only the TV switches from stand by.
