Antenna tv not auto-tuning
RadTech24
Help! I am currently trying to connect my LG webOS TV UN73006LA to antenna, but it is not doing anything. I did an auto tune on antenna cable and satellite, but none of them did anything. My location is set to United Kingdom, and I am selecting DTV, but it detects zero channels. One thing though, I am using a male to male adapter, if that matters. Someone please help!!!
JayCee
You need to check there is definitely a signal coming from the aerial (and the male-male adapter) using another known working TV.
There is no point in selecting satellite as that requires a dish/LNB.
RadTech24
I only have one tv and I’m not really willing to buy another one.
JayCee
Did you have a working TV on that aerial point using the adapter before attempting to tune your new one?
Is that the only aerial outlet in your house?
I wasn't suggesting you buy another TV, can you temporarily borrow one from a friend, relative, neighbour?
JayCee
Can you attach a picture of your antenna (aerial) point and the adapter you're attempting to use?
Did you have a working TV before this new one?
Is there an aerial or satellite dish at your property?
RadTech24
No, and also as we use large widescreen TVs, its not really possible.
RadTech24
Ok attached.
JayCee
When tuning you need to select Antenna DTV (Not Cable or Satellite)
Did you use that aerial outlet on the wall with a previous TV?
JayCee
My money's on a fault in the aerial, it's highly unlikely your new TV is faulty.
Try a male to male aerial flylead.
Check where that aerial outlet goes to…any splitters in the aerial chain?
RadTech24
It’s not a “new” tv, we only just recently got a tv licence. We actully have 2 aerial, and 2 ports, but I’m not sure which one is which. I checked the aerial closet to the outlet, and it seemed fine expect for the fact that the cable leads into the gutter. Does this mean we have to get a electrician to examine this? Plus, the outlet is right on the wall of the neghbouring property, so it’s pretty hard to examine.
Antenna/aerial (DVB-T/T2) services only use push-in (Belling-Lee) connections - see left. Satellite dish (DVB-S/S2) services only use screw type F connections - see right.
RadTech24
Ok then! BTW I am defiantly using a coAx port and not a f-connector. One thing though - the cable doesn’t go in fully into the wall socket, but there is a obvious wall that is stopping it from fitting in fully. Could this cause any problems?
The connectors on both ends of your TV aerial lead/cable must look like the 'male coax' only...
JayCee
I'm sorry, but you’re not making much sense. Your pictures in post #7 show a standard wall-mounted coax aerial outlet plate. Behind this plate there should be a recessed box mounted in the wall that the aerial downlead enters from behind and is connected to the outlet plate.
The “wall” cannot “stop” the coax plug from being pushed fully home. As long as the centre pin of the coax plug and the outer rounded screen mesh fully with the socket that's all that's required for a good solid connection.
Best to call on the services of a local aerial company to check it.
