Antenna booster
Discussion in 'Home Cinema Building DIY' started by meychoon, Nov 7, 2001.
  1. meychoon
    meychoon
    Hi out there, please can anyone help?
    I am having problem with my tv booster. I want to run 4 tv from the same antenna, (distance between each tv 15m) and at the moment I only get good picture from first tv. Picture on last tv is very bad. The booster I have is just before last tv in line with 3 proper splitter used. Is it possible to improve? What can I do?
    Thank you
  2. Metric
    Metric
    add another booster
  3. encaser
    encaser
    Mar 15, 2001
    3,593
    Suffolk/Essex
    +1,207
    should be able to get a booster with 4 outs no probs:p
  4. paiger
    paiger
    Fit a splitter/amp unit in loft with 4-6 outputs. This will deliver an equal signal to each TV. You can get them in B&Q, Maplin etc. If this is not enough a masthead amplifier can be added.
    S
