Anoying options on Panasonic E95
Discussion in 'Blu-ray & DVD Players & Recorders' started by eternaldark, Apr 13, 2005.
  1. eternaldark
    eternaldark
    Oct 23, 2004
    1,410
    Inverness
    +62
    Guess i got too used to the layout on the HSR-52, but i find it really irritating when i press sub menu, the first thing to choose is erase!, I would have prefered to be able to choose which ones i use most, which would have been partial erase, enter title, divide, guess theres no way to change this?
    Also when creating a disc, I found that the text when you enter a title doesn't wrap the words round the box under the thumbnail, until i noticed i was stuck with a disc with words cut in half! If there any way to enter a title that doesn't need loads of spaces to make it look neat when your dubbing a disc?
    its little quirks like that, that make it really annoying I prefered the menu option the the hsr-52, you would just press right on the remote to access the menu for erase etc, I find it long winded to press sub menu, then edit, to find my most used choices :mad:
  2. GASWATKINS
    GASWATKINS
    Mar 11, 2003
    245
    +10
    Its a great machine
    but it takes a bit if learning
    plus the brochure seems a little odd
    what we need is a members guide book
    ie how it really works !!
