Another Xbox + Chipping Thread. :-o
Discussion in 'Xbox Forums' started by Pulsar, Feb 2, 2003.
  1. Pulsar
    Pulsar
    Jan 19, 2003
    2,927
    West Midlands - Stourbridge
    +292
    Hello.
    Before I start, I will confirm that I have just read loads of threads about xbox's and chipping them, and realise that some members of the forum will be sick of seeing them. I just need to confirm a few things before investing my cash.
    Firstly I like the look of this website http://www.premodded.co.uk/chipping.htm
    I already have a non-modded xbox on XBL. These are the things that I want to achieve by chipping my XBOX:
    I want to be able to play games from the US and Japan.
    I want prog scan output via my HiDef AV pack.
    I would like to be able to play all region DVD's in prog scan if possible.
    I don't want to lose XBL.
    I would like to be able to rip games to that hard drive.
    I think that is about it.:clap:
    My other question is, how hard is it to fit a bigger hard drive in the xbox, and does anything special need to be configured. Also is there a limit to the size of the HD that can be fitted.
    If anyone can answer these questions, then please help. Also if anyone can suggest a better company to use to chip the XBOX, then fire away:)
    Rob
  2. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,187
    41
    London
    +6
    As I understand it changing anything like hard drive/BIOS will boot you out of Live even if you have a Mod chip switched off.
    Regards,
    Neil.
  3. holtehero
    holtehero
    Sep 10, 2002
    2,790
    Cambridge
    +1,785
    That site has a good reputation, judging from feedback i have seen on another forum, going to buy from them in the next month or so.
    If you get one of the Xecuter mods, i believe it will allow you to store several version of bios on the chip, that way you can switch between them for different use.
    Also, if you get one with a bios disable switch this allows you to revert back to a non-modified bios so it will appear as if no modding has been done.
    There were issues i believe some time ago with fitting version 1.1 xboxes with a larger HD and a modchip, probably best to mail the guys at premodded as they would be able to answer all the questions
  4. geordie_blerk
    geordie_blerk
    Feb 16, 2002
    39
    No it won't. I have a 120GB hard disk in mine and I can switch back to the original BIOS (by hitting the eject button while a game is booting up) to go Live anytme I want to.
    I have the Matrix modchip.
  5. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,187
    41
    London
    +6
    Thats useful to know, but I don't think it applies to all chips so beware.
    Neil.
  6. Trig
    Trig
    holtehero
    Which site is that ?
    Am also considering a box from them.
    Ta
    Trig:)
  7. holtehero
    holtehero
    Sep 10, 2002
    2,790
    Cambridge
    +1,785
    check here
    and here
    Seems like he is well respected for good service and fast turnaround.
    Haven't yet bought one, but if i do, it will be from him
    Hope this helps
    HH
  8. clarkk
    clarkk
    Jan 28, 2003
    724
    UK
    +15
    Not sure about the progressive can cos I havent got the kit to use it, but as for the HDD, you need to "lock" the HDD,this is an IDE standard practice, but isnt implimented very widely/well, some HDD's just wont lock or are a pain to... you can put anything upto 120gig in the xbox, thats the bios's limit, but you want to get a HDD that isnt noisy and doesnt produce much heat, I went for the Seagate 80gig 5400 rpm... and that locked fine...
    As long as you have a lockedHDD, you can disable your chip and use live with no problems... this is with all chips that support HDD swap... which is all the newer ones... I'd recommend either the chips from www.mrmodchips.co.uk or www.cheapmod.com, mrmodchips does installs too...
  9. Pulsar
    Pulsar
    Jan 19, 2003
    2,927
    +292
    I am quite capable with PC hardware, so changing the drive should be fine, but how do I lock it? And how do I re-install the OS?
    Rob
  10. mandlebrot
    mandlebrot
    Aug 21, 2001
    426
    16
    Manchester, UK
    Does the cheapmod allow the same stuff has all the other chips? Does it allow the following:-
    1) play backups?
    2) play any-region dvd?
    3) allow HD change
    4) play games directly off the HD
    5) Play VCDs original and backups
    6) allow to run software to play Divx?
    I can't seem to find this info on the site, please help :confused:
  11. clarkk
    clarkk
    Jan 28, 2003
    724
    UK
    +15
    HDD Locking: You use a program called Configmagic and it does it all for you... just so long as your HDD supports it... to swap it you need to backup your existing HDD and put the new data on it, www.xbox-scene.com have tutorials on it.
    As for the cheapmod, it runs the xecuter2 bios, but you can put any 512k bios you can get hold of on it, so:
    1) play backups?
    Yes
    Yes, via. DVD-x
    3) allow HD change
    Yes
    Yes, via evo-x or nexgen
    Yes, Xbox Media Player just put this functionality in their code.
    Yes, the above Player.
  12. mandlebrot
    mandlebrot
    Aug 21, 2001
    426
    16
    Manchester, UK
    Thks clarkk for the info:smashin:
    Just one more question, what advantages are there to using the xecuter 2 pro or lite (apart from multiple bios) mods over the cheapmod if they run the same bios?
  13. clarkk
    clarkk
    Jan 28, 2003
    724
    UK
    +15
    Personally I prefer the x2 lite because you can use 2 bios's and switch between the two... I have a switch that allows me to boot off the c partition in one position, and f on the other position... quite handy... thats the main reason... and you can now get pogo connectors for the x1 lite... dont get the pro, you wont need it :) For most people, the cheapmod is the best bet...
  14. mandlebrot
    mandlebrot
    Aug 21, 2001
    426
    16
    Manchester, UK
    Thks for the info again. So basically apart from the extra bios there is no difference then, although I think you can flash protect the bios of the x2 but not the cheapmod which could be a problem is someone decided to write a malicious program, then again it wouldn't be to hard to pop the bios chip out of its holder and re-prog it.
  15. mandlebrot
    mandlebrot
    Aug 21, 2001
    426
    16
    Manchester, UK
    Well I've gone and done it using the cheapmod and it wasn't to hard. Just for information the cheapmod now also has a flash protect jumper but they haven't updated the web site to mention it. So you get an even better product than you are expecting:D :D :D
  16. kevenh
    kevenh
    Jul 3, 2002
    342
    19
    Royal County Of Berks...
    cheapmod does look interesting!
    But is it 'wife' proof?
    I bought her an Xbox 'cos she wanted a DVD player of her own so she could watch a dvd while I was watching a war film on the main TV. :rolleyes:
    With the cheapmod sneakily added into her xbox/dvd player will she notice? Is the operation as a DVD player effected? Does the Xbox video O/P look different (the startup logo, etc.).
    Is the solution to use a switch on the 'mod'? I expect it is.
  17. NeoBlade
    NeoBlade
    With DVD-X the bootup sequence will be different than the retail locked one... But its hardly an issue since it enables multi-region playback. I hardly use my Xbox as a DVD player but the quality is okay.
    Having a switch can help if you plan to use XBL but I've heard rumblings that (now) with XBL Microsoft will check the partitions for certain files that shouldn't be there and will alter them without user discretion. How true is this I haven't got a clue since I don't plan to use the XBL service, but its worth keeping tabs on the "modded Xbox with Xbox live" scene.
  18. mandlebrot
    mandlebrot
    Aug 21, 2001
    426
    16
    Manchester, UK
    If you install the cheapmod then the bootup will look just normal to your wife as nothing is changed visually. The appearance only changes when you start to update the dashboard or install media player. You don't have to install these to play backup games and if you want to watch a DVD from a differen't region then you boot up using DVD-X which will then change the boot apperance but once you switch off and back on without DVD-X disc then all looks normal again so she won't know. You could install a switch has the cheapmod does have this facility but unless you plan on using X-box Live theres currently no need for the switch. My daughter won't be using Live so I haven't installed a switch but just in case things change and I need a switch, I have made the link wire (part of install and place to put switch) long enough to be able to just cut and thread through a vent hole, so adding a switch will be easy.
  19. kevenh
    kevenh
    Jul 3, 2002
    342
    19
    Thanks for the info. I appreciate your effort.
    No! Wait. There's still something I need confirming.
    If I understand right, import Xbox games can be the R1 DVD format. So you need the DVD-X, and the cheapmod if you want to buy cheaper imports.
    Yes?
    I think being able to buy and use US Xbox games is the main thing I want.
    The wife knows she can only play R2 DVD's with the Xbox as it is...
  20. kevenh
    kevenh
    Jul 3, 2002
    342
    19
    well, I did hijack some one elses thread!! :(
    but if one of you could take a minute to confirm that just a cheapmod (or similar) mod allows imports to be used on a UK XBOX, I'd appreciate it.
  21. kevenh
    kevenh
    Jul 3, 2002
    342
    19
    Ahh! :laugh: Point taken, it's in the FAQ.
    To play a US XBOX title IS a two step process.
    Chip the Xbox, then use DVD-X to get the R1 title recognised.
  22. mandlebrot
    mandlebrot
    Aug 21, 2001
    426
    16
    Manchester, UK
    I pretty sure you can just play R1 games has I have already done it no problems although this was a backup not an import if you know what I mean. I think the region X is only needed to play R1 moivies.
  23. kevenh
    kevenh
    Jul 3, 2002
    342
    19
    So it IS a little confusing then.
    :confused: I shouldn't have been to embarassed about asking after all.
    anybody playing US XBOX titles that aren't 'backups' with JUST a cheapmod?
    Ta [for past and future feedback]
  24. Bob Todd
    Bob Todd
    Aug 20, 2000
    3,080
    UK
    +373
    i have been talking to the premodded guy, via email I think i will get one from him.
  25. Willy
    Willy
    Jan 4, 2003
    466
    19
    Bedfordshire
    I'm playing an original US version of Halo on mine. However it has an Xecutor 2 rather than a cheapmod. Got mine fitted for £50 though, so it's pretty affordable. Bloody quick too - mine was done in about 1/2 an hour.
  26. mandlebrot
    mandlebrot
    Aug 21, 2001
    426
    16
    Manchester, UK
    Cheapmod uses the Xecutor 2 Bios so its basically the same with the only main diff being the multiple BIOS chips on the Xecutor 2 allowing you to interchange between different ones has and when they become available. This is my understanding of it anyway.
  27. Willy
    Willy
    Jan 4, 2003
    466
    19
    Bedfordshire
    Yeah, that's how I thought it worked, but I didn't want to say too much in case I was wrong: I'm pretty new to all this importing malarkey.
  28. kevenh
    kevenh
    Jul 3, 2002
    342
    19
    Thanks for the clues about what to surf for ;)
    The Xecuter Bios does this and more: -
    - Direct boot ALL backups
    - Direct boot ALL original imports
    - Direct boot ALL unsigned code (Homebrew)
  29. mandlebrot
    mandlebrot
    Aug 21, 2001
    426
    16
    Manchester, UK
    So now you got that cleared up and the fact that the cheapmod very cheap at £16 including P&P does indeed uses the Xecutor 2 Bios, are you going to buy one and get on with enjoying your backup/imports?
  30. kevenh
    kevenh
    Jul 3, 2002
    342
    19
    You know what, I think I will!
    Do you (mandlebrot) have a connection with cheapmod, or just curious?
    It will be after I've bought a soldering iron, etc. though :D and then finished my HC project (only a little left to do)
