Another which one ?
Discussion in 'LCD & LED LCD TVs Forum' started by dmsims, Oct 5, 2004.
Tags:
  1. dmsims
    dmsims
    Sep 19, 2004
    53
    Taunton
    Logik (currys) 27in for 899
    or
    Samsung LW22a13 22in for 760
    TIA
  2. alscds
    alscds
    see if yiy can find the older sharp 22 for the same price or the previous panny 22
  3. fozzy73
    fozzy73
    Avoid the logik tv if i were u for time being until they sort out the audio issue on them shud be iminent
  4. andrew markwort
    andrew markwort
    Jun 20, 2004
    1,156
    63
    +159
    Fozzy, you've attacked the Logik's sound on another thread and as I've said there, what's the cause of your beef, please? I've used our Logik consistently over the past few months with no problems. I wouldn't use the sound for home theatre presentations, but having said that, who would use a TV set's speakers for home theatre?
    Unless Fozzy has some info about a genuine lurking problem with the Logik I'd recommend it. The picture is excellent but I would say that you've got to be patient and tune it in properly with the help of a calibration disc. However, the time you spend on this will be rewarded.
