Another which Harmony remote do I need thread
Discussion in 'Home Cinema Control & Remote Controls' started by Marshall Mike, Apr 25, 2016.
Tags:
  1. Marshall Mike
    Marshall Mike
    Aug 9, 2014
    1,412
    3
    116
    Prestwick, Scotland
    +985
    So I have a Sony PJ, Anthem receiver, Sky+HD and a Xbox One.
    None of the gear is hidden away. The Xbox is used as a Blu-Ray/Media player and has Kinnect hooked up to it. I would like to be able to fully control the Xbox with the remote, including Netflix and Amazon Prime if possible.
    Suggestions please? Thanks!
  2. logiciel
    logiciel
    Feb 2, 2008
    53,057
    UK
    +5,738
    Any Harmony!
  3. Marshall Mike
    Marshall Mike
    Aug 9, 2014
    1,412
    3
    116
    Prestwick, Scotland
    +985
    Ok that's good to hear, thanks. But why are there so many to choose from? What are the differences? I'm thinking maybe the ultimate one as the elite would be overkill?
  4. logiciel
    logiciel
    Feb 2, 2008
    53,057
    UK
    +5,738
    There are about half a dozen current models, of which the 350, 650, and Touch would meet your needs.
    The Ultimate One is unnecessarily expensive and the other two can control devices without line of sight.
  5. Marshall Mike
    Marshall Mike
    Aug 9, 2014
    1,412
    3
    116
    Prestwick, Scotland
    +985
    Ok thank you, the touch and ultimate one only have a £5 price difference on Amazon so think I will go with the ultimate.
  6. logiciel
    logiciel
    Feb 2, 2008
    53,057
    UK
    +5,738
    I was going by the prices on Logitech's own web site.
    A couple of things to bear in mind are that the Touch and Ultimate One have direction controls in a crazy position and don't have number keys, which are both corrected in the 650.
  7. Marshall Mike
    Marshall Mike
    Aug 9, 2014
    1,412
    3
    116
    Prestwick, Scotland
    +985
    Ah you mean the D pad is at the bottom and hard to use? I'm not sure if we would miss the number buttons, we tend to choose channels from the sky guide.
    Apart from the touch screen, are there any other differences between the ultimate and 650?
  8. logiciel
    logiciel
    Feb 2, 2008
    53,057
    UK
    +5,738
    The record/play commands are at the top of the Touch and Ultimate One, above the screen.
    On the 650 they're in the more usual position of below it.
    The T and UO are very different in style from the 650.
    In usage the former do offer more than the latter.
  9. Marshall Mike
    Marshall Mike
    Aug 9, 2014
    1,412
    3
    116
    Prestwick, Scotland
    +985
    Ok thanks for all of your advice @logiciel, I have placed an order for the Ultimate :)
  10. logiciel
    logiciel
    Feb 2, 2008
    53,057
    UK
    +5,738
    You're very welcome. It's the Ultimate One that you've ordered?
  11. Marshall Mike
    Marshall Mike
    Aug 9, 2014
    1,412
    3
    116
    Prestwick, Scotland
    +985
    I just realised there's a difference isn't there? The Ultimate One is the stand alone remote and the Ultimate is the remote and Hub?
    So if yes, the Ultimate One is what I have ordered.
  12. logiciel
    logiciel
    Feb 2, 2008
    53,057
    UK
    +5,738
    That's fine. You'll like it.
  13. Marshall Mike
    Marshall Mike
    Aug 9, 2014
    1,412
    3
    116
    Prestwick, Scotland
    +985
    Yeah I'm looking forward to going to one remote, just hope my wife gets on ok with it :confused:
  14. logiciel
    logiciel
    Feb 2, 2008
    53,057
    UK
    +5,738
    :thumbsup:
  15. Marshall Mike
    Marshall Mike
    Aug 9, 2014
    1,412
    3
    116
    Prestwick, Scotland
    +985
    The remote arrived yesterday and I set it up last night. I have to say I'm impressed so far :thumbsup:
    From the testing I done last night though, when switching everything on at once (PJ, receiver, sky) with an activity if my receiver is on a different input it doesn't seem to change to the correct one. The help feature rectifies this and there's no problem switching between activities when the receiver is already on. I looked at setting a delay, but you cant place the delay in the sequence so the amp switches on and then changes to the correct input after a few seconds? The delay could only be placed at the end?
  16. logiciel
    logiciel
    Feb 2, 2008
    53,057
    UK
    +5,738
    As Help fixes the problem it should be easy to make that permanent.
    Doesn't it have an indication of how to do that?
  17. Marshall Mike
    Marshall Mike
    Aug 9, 2014
    1,412
    3
    116
    Prestwick, Scotland
    +985
    Not that I know of? It just asks if it worked, I hit yes and it returns to the activity as normal.
  18. logiciel
    logiciel
    Feb 2, 2008
    53,057
    UK
    +5,738
    I don't have an UO but Delays should fix it.
    Try various values of each one and if necessary ask Logitech Support.
  19. Marshall Mike
    Marshall Mike
    Aug 9, 2014
    1,412
    3
    116
    Prestwick, Scotland
    +985
    Found the delays in the remote menu itself, I had been trying to add them on the PC so all sorted now :thumbsup:
  20. logiciel
    logiciel
    Feb 2, 2008
    53,057
    UK
    +5,738
    Excellent - well done.
