markstephenhall
What is your budget?
£400-£550
What size laptop do you want?
(In terms of screen size)
Netbooks are usually less than 11"
Ultraportable laptops are usually 11" to 13"
Standard laptops are usually 14" to 16"
Desktop Replacements are usually over 17"
13" - 16"
Do you have resolution requirements?
For example "must display 1080"
Higher the better.
Do you prefer a matte or glossy (reflective) screen?
Please note matte screens are harder to find these days, so may not be in budget.
Either.
What will you be using the laptop for?
For example, Browsing, Gaming, Word Processing, Video Editing, Web/Graphic Design
A bit of everything.
If you will be gaming, what games do you need to play?
Strategy/simulation
How long does the battery need to last?
3 hours
Does it need to be portable?
Portable around the house. Will rarely leave the house apart from odd work trips away as it will be used for a small home business too.
Do you require Blu-Ray?
No.
Do you require HDMI output?
Not essential but would be nice to use external tv/monitor.
Do you have a preferred brand?
For example Dell, HP, Acer
Dell/Samsung/Lenovo/Acer/Asus
Are there brands you would prefer to avoid?
HP/Packard Bell/Sony/Medion
Would you be happy with a refurbished laptop?
If it offered a good spec for less price. Have been watching Dell Outlet but not got anything so far.
Any other details you feel necessary... Colour; Webcam; Good quality speakers; general spec: CPU, RAM, HDD space, SSD; Operating System or anything else you can think of.
Decent webcam. i5/i7 CPU, 8gb Ram, Min 500gb Hd unless ultrabool with SSD, i can take os from old laptop if it is worth it. USB 3.0 port.
My last laptop lasted from 2005 as it was a top spec configured Dell Inspiron so would like its replacement to do the same if possible!
Thanks guys
£400-£550
13" - 16"
Higher the better.
Either.
Strategy/simulation
3 hours
No.
Thanks guys
