Another: what cables should I buy for my new equipment. Please!
Discussion in 'Cables & Switches' started by Famished, Jan 11, 2005.
  1. Famished
    Famished
    Right just ordered the following
    Philips 28" 28PW6518C Real Flat Widescreen TV Inc Cabinet
    * 28"(66cm) Screen Size
    * Virtual Dolby Surround Sound
    * Fastext
    * 2 Scart Sockets
    * RGB via Scart socket
    * Front AV Input
    * S-VHS Socket
    * On Screen Menu
    * Auto Set Up
    * Headphone Socket
    * 16:9 Widescreen format
    * Pure Flat Screen
    * Stand Included
    Amp and Speakers
    Sony HTDDW760
    # 5.1 reciever package
    # Dolby Digital, DTS, Dolby Pro Logic 2
    # 80W x 5 + 100W subwoofer
    # Pre programmed remote commander
    I also have a Sony DVD player which I will be connecting up
    What cables so I need to buy to ensure that I have the best picture quality and have Dolby Digital 5.1 Sound from the TV and DVD player.
    Many Thanks for your help in advance.
    Nick
  2. Famished
    Famished
    oh and the DVD player is a Sony DVP - S336
  3. nwgarratt
    nwgarratt
    May 5, 2002
    27,030
    +2,979
    You just need a fully wired scart cable and set the DVD player to RGB. Then attach to the RGB scart of the TV (usually AV1).
    Then use either a optical or coaxial digital cable from the DVD player to a digital input on the amplifier. Check if you have both types or just one of these on the player.
    You can only get DD 5.1, DTS 5.1 or DPL 2 from the amplifier. You will still get 2 channel sound from the TV.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
  5. dekoded
    dekoded
    Oct 30, 2004
    893
    Blackpool
    +45
  6. Famished
    Famished
    I thought that the amp would split the sound up from the TV to make it 5.1? How do I connect the TV to the AMP? is it only through the DVD player?
  7. nwgarratt
    nwgarratt
    May 5, 2002
    27,030
    +2,979
    The TV is not 5.1. It is only Dolby Surround. The only way to get the sound from the TV is to use a red and white phono cables from the TV to a suitable input on the amp. You will get 2 channel stereo or Dolby Pro Logic from it (when watching a Dolby Surround transmission).
  8. Famished
    Famished
    ah I see, but I assume that the sound from the 5.1 setup will sound good enough to at least mimic true dolby digital.
  9. dekoded
    dekoded
    Oct 30, 2004
    893
    Blackpool
    +45
    I'm not sure what you mean, the sound from the 5.1 setup is or should be true Dolby Digital or DTS.
    When you set up a home cinema system you should split your system into 2 systems, one for the video and one for the audio. If you think of it this way then it will be simpler to understand.
    Most people use their tv/lcd/projector/plasma as purely a visual device and then use their AV amps and speakers for the audio. Quite often it's necessary to mute or lower the volume to zero on the tv.
    You probably don't need to connect your tv to your amp, simply use the digital optical/coaxial connection from the dvd player to your av amp. This single connection will carry all 6 channels from the dvd player to the av amp for decoding-then to your speakers.
    I hope I haven't been too patronising, I realise that alot of people have never setup a home cinema system before and it can seem a bit complicated to the newbie :smashin:
  10. Famished
    Famished
    Cheers for your help mate, I understand what you are saying. I will connect my DVD to my amp but when I actually just watch normal TV can I get the sound to come out of all the surround speakers or does that just happen when I watch a DVD with surround sound or play a game on my Xbox?
  11. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    for that you need analogue stereo pair and to use the Pro Logic 2 system on AMP which will mix 5.1 out of stereo
  12. Famished
    Famished
    can you point me to a link at all?
  13. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
  14. Famished
    Famished
  15. Famished
    Famished
    Connectivity
    Number of scarts : 2
    Ext 1 Scart : CVBS in / out, RGB
    Ext 2 Scart : CVBS in / out, S video in
    Other connections : Audio constant level out
    Front/side connections : Audio left / right in, CVBS in, Headphone out
    here are the connections with the TV I assume that this TV has audio outputs ment by "Audio constant level out"
