:: Another what Cable thread, need to show xbox I care ::
Discussion in 'Cables & Switches' started by Tob3z, Mar 17, 2005.
  1. Tob3z
    Tob3z
    Jan 17, 2005
    194
    19
    Newquay, Cornwall
    Hey all,
    I am about to buy a new setup.
    Denon 2105 Amp
    Epos ELS3 5.1
    A panny 32"... not sure which one yet.
    Just wanted to know what are the best cable type to use for connecting my xbox up.
    So Im guessing optical is the best for 5.1 But I am not sure on video.
    I have seen a (what I think gd) site. http://www.monstercable.com/monstergame/xbox/
    Could I get a little help on this please
    Tob3z
  2. nealgs
    nealgs
    if the t.v. you get supports component connections, they purchase the official MS Hidef kit from www.dvdboxxoffice.com or www.lik-sang.com (search of forums will pickup more details on this product)
    Third party ones have mixed reports, I use a third party one and picture is fine
    regards
    Gary
  3. Wannabe-THX
    Wannabe-THX
    Apr 7, 2004
    253
    I use the MS scart cable with optical to the processor, and when playing in serious mode I use the component to the projector, But not sure about getting the 5.1 that way though. :(
    Fish
  4. nealgs
    nealgs
    MS hidef kit supports optical digital audio, some of the third party ones do also - The monster one linked to only has stereo audio via phono leads
    Gary
  5. Tob3z
    Tob3z
    Jan 17, 2005
    194
    19
    Newquay, Cornwall
    but theres a optical cable there. But like I said I know jack (nice guy)
  6. blitzed
    blitzed
    Mar 14, 2005
    384
    28
    hayes
    +43
    hi ,
    im using xbox hidef kit excellent pic with this just make sure ur xbox is modified to change eeprom to ntsc mode
    ed
  7. nealgs
    nealgs
    Hi Tob3z, the GameLink™ 400 X Component Video with Analog Audio, only has the red-white phono for analogue stereo (looking at the picture) but as you mentioned it does have a digital output jack, so you can connect a optical digital cable to it - will read specs next time :smashin:
    The MS one is still the one to go for by all accounts :)
    cheers
    Gary
  8. Tob3z
    Tob3z
    Jan 17, 2005
    194
    19
    Newquay, Cornwall
    could I have a link to this Hi Def cable please. Somewhere I can buy it.
    Also is it gold plated?
    Thanks peeps
  9. nealgs
    nealgs
    the original two links are were to get it from - it's not available in the uk due to the UK PAL Xbox'x not being enabled for hi-def/component etc.
    Either Cananda (dvdboxoffice) or asia(?) lik-sang.com are the two places most people have used
    can't find item on dvdboxoffice for some reason, but lik-sang is here http://www.lik-sang.com/info.php?category=53&products_id=1742&
    regards
    Gary
  10. scumball
    scumball
    Jan 12, 2004
    6,533
    Harrow - London
    +452
  11. Tob3z
    Tob3z
    Jan 17, 2005
    194
    19
    Newquay, Cornwall
    wow... thanks. Thats cheap, and free shipping.
  12. shaithis
    shaithis
    Feb 25, 2005
    1,668
    The Last Aerie
    +31
    Non-offical ones dont do progressive scan correctly but the offical one doesn't work until you turn the XBox to NTSC.
  13. Tob3z
    Tob3z
    Jan 17, 2005
    194
    19
    Newquay, Cornwall
    Now on my crap ass 20" when I switch to NTSC it looks a bit blured. This wont happen with a sweet ass PD50 will it?
    edit:: Just to lear things up how will I connect this then.
    Optical audio output to amp
    and Component to amp
    is that right. Is component audio or video. If its audio then I guess its scart to tv.
  14. nealgs
    nealgs
    component is 3 cables RGB or YUV this is the video part of it
    Gary
  15. Tob3z
    Tob3z
    Jan 17, 2005
    194
    19
    Newquay, Cornwall
    nice one, thanks for your help. I ordered from lik sang as it was cheaper.
    Now I will prob have to wait 4 weeks before I see it :D , ok maybe 2 weeks.
  16. john<|>nhoj
    john<|>nhoj
    http://archive.avsforum.com/avs-vb/history/topic/407698-1.html
    Just did a search to see if the monster cable was worth the extra... Someone here does not seem to think so... I will be going for the MS version I think.
    Does this mean my Xbox will have issues playing standard DVD's ? If I run in NTSC or is it just the output format... My Xbox is modded so that side is ok...
