madfiddler
I thought I should make a quick post after having picked up my custom TV unit from Stump furniture this week
Reclaimed Furniture | Handmade Kitchens | AV Furniture - Stump Furniture
Stuart has been great to deal with from beginning to end and I have a real quality product that was definitely worth the money and the wait. When you think about what you can buy mass produced out of glass, plastic and mdf and the cost for something decent that you end up having to fit your room and equipment around, its really a no brainer to go and get a custom unit built. If you are thinking about doing this, then think no more and ring Stuart now!
I had an oak/oak veneer unit built with a natural wax finish to blend in with other furniture and flooring. Unfortunately my cheap-ass gale speakers now stand out a bit so they'll be next on my shopping list to be replaced!
There is enough space for a centre speaker at the top and xbox Kinect. Left hand side at the bottom is a removable shelf. There is a solid back with cable holes, space at back of the shelves for cables to pass up/down and ventilation holes in the shelves too.
Very happy - as is SWMBO to see that the spaghetti of cables are now all out of sight!
Here are some shots of the unit in the workshop that Stuart took and a couple (of dodgy) ones with it in situ.
cheers
all
cheers
all
