Xbox 360 Autoupdate
Posted: March 2, 2006 @ 12:51 pm (27 minutes ago) By: Major Nelson
There is a mandatory global system update now available for Xbox 360 owners. Youll get prompted for the update the next time you sign into Xbox Live. No new features or functions this time around.
Varies from game to game, although most do.A406 north circ said:Must be my imagination then![]()
dodger747 said:Auto run feature can now be turned off???
/please say yes...![]()
Batch said:I'm having trouble updating! the first update progress bar goes to 100% but then the second stop at about 10%. An error appears saying that there may either be a network error or a storage error! Obviously i must be connected to live to have the update pop up and my HDD has 9GB free! Any ideas why i may be getting this error?
Batch
royster said:The update will not be looking at your hdd size as it is flashed to rom inside the xbox. Check your network settings and if you are downloaded on a pc or using any others internet apps quit them and try that.
