Another takes the plunge..
Discussion in 'Plasma TVs Forum' started by martinthorn, Aug 26, 2005.
  1. martinthorn
    martinthorn
    Well, I had an Hitachi PD5200H on order until Wednesday this week when I saw one hooked up to a DVD player in Comet. Hope this doesn't cause flames (sure it will though :) ) but I changed the order because I felt there was too much banding on faces during motion on DVD. It could be that this was due to low bit-rate (it was an extra feature on the Little Stuart DVD) but I wasn't prepared to chance it given the sums of money involved, so..
    I plumped for the JVC PD-42DX6 instead. It's a few hundred quid more than the Hitachi, but was prepared to pay for a (perhaps!) a better picture.
    TV arrived today, managed to get it onto a stand with a herculean effort ! (Think olympic powerlifters ;)), switched on and the immediate picture on Sky through RGB was very watchable. A few tweaks later (reduce brightness, contrast and so on) and the picture is great. No banding so far, contrast is good, no greeny blacks or noise.. Quick look at a Star Wars (AOTC) DVD through RGB standard def shows a superb picture. I will give it a futher shakedown tonight when the sun has gone down (lose the reflections on the screen !).
    Analogue picture is good, channel 4 has great reception ; cricket is better on here than on sky due to mpeg compression artifacts that are just visible.
    So far a very happy plasma viewer !
    Martin
    ps. bear in mind this is my first plasma, and that although I think the JVC is great so far, the Hitachi may have been just as good given the chance ! The equivalent Panasonics and Pioneers are more expensive..
  2. Badger0-0
    Badger0-0
    May 30, 2005
    20,593
    Spaghetti Junction (really)
    +1,921
    You made your own choice mate :thumbsup:
    That's all that matters.
    Never seen a JVC and don't know how it's rated.
    But who cares??? you're happy, so nice one, IMO.
    But I bet you will get someone say "you should have bought a panny" :(
  3. cliveuk
    cliveuk
    Aug 20, 2004
    524
    28
    Folkestone, UK
    +45
    yep the only good choice is the the Plasma thats right for you.
    ive never seen a JVC plasma so like badger i dont know what they are like but as long as your happy thats all that matters :)
  4. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,175
    Norwich
    +794
    What a refreshing post, someone who went to see the screen and had the ****** to say it wasn't the one for them.
    Now get off the forum for a while and enjoy your new screen mate!
  5. chris
    chris
    Nov 20, 2000
    1,226
    romney marsh, kent, uk
    +28
    JVC are made by Panasonic.......so he has got a panny.. :)
  6. martinthorn
    martinthorn
    sounds like good advice..
    Neither had I until today and there are no reviews of this Hi-Def model because it's quite new.. however the only review I could find of a JVC Hi-Def was encouraging (a panel only affair : ie. not a TV) so went for it. Like I said the Hitachi may have been fine but am very happy with the JVC thus far.
    It does buzz though so perhaps it is a PV500 with a different name ;)
    Not an intrusive one mind you, but mute the sound and it's there.
    Martin
  7. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,175
    Norwich
    +794
    Can't be a PV500, doesn't look anything like it! :)
    [​IMG]
  8. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,175
    Norwich
    +794
    Reading the spec. it says
    Capability to receive HD 1080i 50/60Hz and HD 720p 60Hz Signals
    Is it HD READY or not?
  9. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,175
    Norwich
    +794
  10. martinthorn
    martinthorn
  11. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,175
    Norwich
    +794
    Where did you buy it from?
    The 2 or 3 places I looked at did have it listed as HD-Ready but JVC don't have it listed as one of their HD-Ready sets.
    http://www.jvc.co.uk/index_hdready.php
    If the place you got it from has it listed as HD ready I would get a screen grab of the page along with a webpage with a date on it in case you need some proof it was misold.
    It may be a panny 7th gen panel with the PV500 bits on it, hence no 50Hz? But JVC may release a firmware update?
  12. Badger0-0
    Badger0-0
    May 30, 2005
    20,593
    +1,921
    And I thought we were going to leave the bloke alone, for making his own (very good) choice :confused:
  13. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,175
    Norwich
    +794
    Haha, the reason I said to get a screen grab now is, you may be able to use it for a few months and then get them to swap it over when prices have fallen again.
    I still think it looks like a great set and I bet it takes all the necessary reolutions at 50Hz on component, looks a good screen to me.
  14. martinthorn
    martinthorn
    As far as I see it the TV supports a number of Hi-Def signals. If I get an upscaling DVD player it will output a signal that the JVC can accept. The question then is what about receiving Sky HD ? I don't know yet if this is ok, but if it doesn't it's not the end of the world as the TV is looking good on SD at the moment..
    I got the TV from here :
    http://ws3.homecinematv.co.uk/showproduct.php?cda=showproduct&pid=JVC-PD42DX6
    where it is correctly advertised.
    Martin
  15. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,175
    Norwich
    +794
    I would email JVC and see what they say about it accepting 720p50 over YUV or VGA if it does that you will be fine anyway.
