Another take on LCD vs DLP
Discussion in 'Projectors, Screens & Video Processors' started by RichardA, May 16, 2003.
  1. RichardA
    RichardA
  2. Anders_UK
    Anders_UK
    The tests were done a while ago now. You can find the white paper on the test and how is was conducted on the TI website.
    I don't ever want to use a Sim6 ever again!!!! They were pants when they first came out and are still pants now!! Plus matching anything up to 12 channels for colour is virtually impossible without effecting dynamic range. Long live the DLP (thank you Larry Hornbeck)
  3. theritz
    theritz
    Aug 17, 2002
    2,455
    Ireland
    +27
    Texas Instruments producing a report which criticises LCD by comparison with DLP ??? Shock ! Horror!
    Sean G.
  4. lmccauley
    lmccauley
    Oct 24, 2000
    3,472
    Newcastle
    +291
    Next DTS will be producing a report to say that DTS is better than DD...
  5. Paul O Hale
    Paul O Hale
    No surprises , the blue lcd assembly bears the brunt of the light input in most Xprism engines designed since the late nineties.
    However the 24/7 operation and the relation to the number of failures bears closer scrutiny.
    I have seen numerous units with thousands of hours on them
    and the the majority of panel failures were with the projectors that either ran 24\7 or operated in smokey and\or dusty enviroments.
    Those that had home cinema type placement or regular down times with attention to filters very rarely showed any panel failure or display problems over the years even with thousands of hours on their clocks!.
    I would also say that there are some newer engines available with slightly different optical layouts that may reduce the problem
    To those LCD owners that may be worried.....KEEP YOUR FILTERS CLEAN!....this more than anything will prolong your projectors life.
  6. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,443
    Somewhere in South Yorkshire
    +5,852
    Yes, my guess is that this is primariluy a heat buildup problem, caused by the continuous nature of the use, plus, probably, little attention to filters and so on.
    My LCD RPTV (now sold to a relative) continues to give reasonable (as good as it ever was) colour rendition after 6 years 'normal' use.
  7. VirusKiller
    VirusKiller
    Mar 15, 2003
    1,807
    Hogsty End
    +70
