Another subwoofer question...
Discussion in 'Subwoofers' started by jonnyv, Apr 10, 2002.
  1. jonnyv
    jonnyv
    Mar 31, 2002
    2,287
    48
    +52
    Just before i go out and buy a new subwoofer (maybe the paradigm pdr10) , I have a question..
    What is the difference between subwoofers ?
    Some being £150 and others £600 !!
    I know the more expensive ones probably are able to produce lower Hz than cheaper ones...
    But to compare my yamaha yst-sw90 with the paradigm pdr10....what are the differences here....And is it worth me buying the paradigm or should i keep the yamaha ?
    cheers
  2. bob007
    bob007
    Cheap subs tend to produce boom, not bass that is tight and controlled. I had the Yamaha YSTW160 for a while but when i upgraded to the REL i could then tell the difference between a good bass and a boomy bass, the Yamaha did give good results some of the time, it does pay to go for a decent sub it makes all the difference. Try a demo only you will tell if it will be a worthy upgrade.
  3. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Not to mention that more expensive subs usually also have a bigger drive unit, essential for more and deeper bass as more air needs to be moved.
    More powerful amps also contribute to higher cost I would imagine.
