SimonO
I had a v1 Sky+ box installed just over a week ago and it's been fantastic up until this evening... Just before the start of the football I got the message 'No satellite being received' initially on my premium channels only and then on all channels... I had a signal, although from day one the two tuners have shown different readings and do seem to fluctuate more than my other Panasonic box which always shows a higher figure and is rock solid..? I switched over to my other box and watched the match, so no problems with the feed from the quad LNB...
After the match I turned the Sky+ back on and it appeared to be working normally although when I checked the Sky+ planner the series linked Grand Designs on CH4 (which should have been recording at the beginning of the match and when the problems started) had vanished although the following weeks episode is still there...
Any ideas..?
I would be very interested to know whether other Sky+ boxes show different and fluctuating readings from the two tuners..?
Any ideas..?
