D
Debs67
Hi!
My Diamond 9CM center speaker manual,says I should set it to large,the auto set up on my Yamaha RXV-650,also sets it as large...but when I follow this (and I might add the center sounds more full on large) my subwoofer either does not switch on,or is on but doesn't seem to be working.But when I switch the center to small,the sub works again.My sub is Yamaha YST-SW215.
I know the obvious answer is keep it on small,but I need to know why!?
My word I'm tweaked out!
Thanks,
Debs
Thanks,
Debs
