another remote code request!!!
Discussion in 'Satellite TV, Sky TV & FreeSat' started by shoties, Sep 14, 2007.
  1. shoties
    shoties
    Aug 23, 2007
    7
    arundel
    Hi, im looking for the sky remote code for Samsung T114B7 its a tv with vcr built in. Im using a revision 8 standard remote. I have tried 0065, 0584, 0672, 0646, 0584 and 0060. any help appreciated, thanks !
  2. deks
    deks
    Jul 12, 2007
    9
  3. shoties
    shoties
    Aug 23, 2007
    7
    arundel
    cheers mate but ive tried searching through that already and generally through the internet with no luck......
  4. Kevosull
    Kevosull
    Sep 1, 2006
    107
    +5
    These are supposedly Samsung codes too, though none is specific to your model of tv.
    037
    060
    065
    088
    100
    118
    236
    244
    245
    292
    318
    398
    476
    516
    584
    615
    642
    646
    672
    Hope you get lucky :smashin:
    Kev
  5. Rom
    Rom
    Aug 16, 2007
    2,064
    116
    Sheffield
    +746
    No 3 digit code worked with my Sammy but the 0060 4 digit code worked.
    Here is how to use the 4 digit codes:
    To program using the 4 digit code
    1) Switch on the TV set
    2) Press the TV button on the Sky Remote
    3) Hold down the select and red buttons for 2-3 seconds until the LED blinks twice
    4) Press the TV button on the Sky Remote again
    5) Enter the 4 digit code for your make of TV
    6) The LED should blink twice, if not recheck the 4 digit code used and go back to 1
    7) Press the standby button on the Sky Remote (The TV should go to standby)
    8) Press select to store this setting
    If the TV does not go into standby press the TV button then the standby button, then TV then standby, keep repeating this until successful. This will scan the codes used for a particular make of TV.
