Another rear speaker placement Q
Discussion in 'Home Cinema Speakers' started by @if ®afiq, Jun 25, 2004.
  1. @if ®afiq
    @if ®afiq
    May 31, 2004
    657
    +20
    I need some advise :lease:
    My room is a really akward shaped loft that was converted not too long ago.
    The front's will be around 4-5ft away from my seating positon - this I cannot change.
    My rears can be in one of three places:
    1) To the side of me, about 2ft away and just above ear height
    2) Slightly further back (about 110 degrees) at a distance of 4-5ft but below ear hight
    3) 10ft behind and well above ear height.
    The ceiling is a no go as it is too low!
    Which is the three would be best?
  2. ShinObiWAN
    ShinObiWAN
    Oct 2, 2003
    749
    16
    Derbyshire
    I'd lean toward number 3 and would rule out number 1 completely as the sound would be very directional at such a short distance as 2ft. Also wouldn't be keen on 2 since they are so low.
    Sounds like you have a crap room really.
  3. @if ®afiq
    @if ®afiq
    May 31, 2004
    657
    +20
    Tell me about it! :(
    Hindsight is a wonderfull thing - if I knew I would be getting into all this home cinema malarky I would have done it differently...
    ...there is a spare room dowstairs - but it just doesn't feel like "my" room...
    ...there's not much that I can move around either - look's like a house move is in order!
  4. ShinObiWAN
    ShinObiWAN
    Oct 2, 2003
    749
    16
    Derbyshire
    Just give it a go for now.
    But I'd definitely prefer 3. You could be pleasantly surprised and a plus point with lofts is the fact that the triangular roof is much better for acoustics and standing waves.
