Another question for H3D owners, Part 2 !!
D
dvdbrowser.com
Can anybody tell me if the Holo3DGraph card will improve
the motion artifacts caused from watching sports from a FTA STB.
Will there be any difference between this and the MSI [email protected]
The reason i ask is because i don't want to splash out on an
RGB to SVHS convertor for the MSI [email protected] only to find that
i will probably be better ending up going with the H3D card
and will have to get a RGB to Component converter for the best
possible picture or will the SVHS input on the H3D suffice.
Anybody?
Many thanks.
Steve.
Steve Bate
Not got much time now but you should see a marked improvement with the de-interlacing on the H3D with sports. It uses Faroudja DCDi and is especially good with fast moving sports.
Steve
D
dvdbrowser.com
Hmmm, Thanks for that Steve.
That's not what i wanted to hear, it's alot of dosh but i like the idea of it. ;)
D
dvdbrowser.com
Steve,
Can the H3D card output PAL OTA broadcasts at 100 Hz refresh rate through the video card or is the output fixed at 50Hz?
Can the refresh rate be changed to anything?
Steve Bate
The output is dictated by the Video Card and your display device The H3D has preset refresh rates of 50, 59.94, 60, 75, 100 and custom (using powerstrip) if you can display 100Hz then yes.
Why 100hz? What is yor display device?
Steve
D
dvdbrowser.com
I want 100 Hz to reduce the flicker on my Panny pw5b plasma.
The 50 Hz signal going straight to the panel via RGBC is abit distracting at times.
