Another pw7 problem!
Discussion in 'Plasma TVs Forum' started by First-Timer, May 1, 2005.
  1. First-Timer
    First-Timer
    I am noticing that the visual is slightly lagging behind the audio which is really annoying. What is this down to? and what can I do about it?
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Is it all inputs, or just sky? It's partly down to a bit of extra processing time, and partly that your screen is now big enough to see the mouths moving accurately, and you are seeing what's been there all along. The usual way of dealing with it is in your AV amp. audio delay is what you need, good amps have it, some scalers do it, or a stand alone box as banner advertised here.
  3. First-Timer
    First-Timer
    i have a denon 2805 av amp that i am bypassing at the moment - will it assist if i route the telewest box picture through this? I would then lose the benefits of the quality of leads going through the JS vga converter. I am routing the audio from the converter to the amp.
  4. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    you don't need to put video through the amp...just audio and set audio delay to solve lip-sync issue (assuming the 2805 has this feature)
