Another problem with sound
Discussion in 'Computer Components' started by Gadjet, Nov 2, 2003.
  1. Gadjet
    Gadjet
    Aug 14, 2001
    411
    Wrexham
    +7
    Hi everyone,
    Well I did buy software to be able to play DD and DTS on pc. The full version of PowerplayDVD 5.0.
    But it wont install. I removed the "cut down" version I had already installed with the PC and the free trial I downloaded before installing Full Version.
    The problem being that it says I have retail version installed on my machine. I have put PowerDVD into search files to find any and deleted them, reatarted and the same problem occurrs.
    Has anyone got any ideas to solve my latest problem. I just seem to keep spending and getting knowhere.
    Once again your help will be appreciated, sorry for spelling 2am in morning.
    I will here DTS one day on this PC (will I?)
    phill
  2. HMHB
    HMHB
    Nov 11, 2001
    25,443
    Nottinghamshire
    +3,744
    Did you remove the software properly by using "Add/ remove programs" in Control Panel ?
  3. Gadjet
    Gadjet
    Aug 14, 2001
    411
    Wrexham
    +7
    Hi John,
    Yes to remove original and trial version, they were both removed by control panel,
    Phill
  4. perrin21
    perrin21
    Sep 30, 2003
    137
    Preston
    +5
    make sure you have restarted the pc prior to trying to reinstall the software. If this fails ctrl alt and del to see if there is still any applications running in the background.
