Another Plumbing Query
Discussion in 'General Chat' started by Dancook, Sep 18, 2007.
  1. Dancook
    Dancook
    Feb 15, 2007
    15,278
    +6,020
    Since seeing the other thread, I have just thought to ask.
    In the kitchen, if the hot tap isn't opened up fully, once the hot water starts coming through it will make a racket! Loud banging noises through the pipes and the hot water splutters, if I fully open the tap the noises goes away and it runs fine. Is this 'water hammer' or something else?
    I can't remember if the same thing happens in the bathroom.
    What are your best recommendations?
  2. dazzafact
    dazzafact
    Jan 9, 2005
    743
    +81
    Never wash up.:D
    what kind of hot water system do you have?
  3. Dancook
    Dancook
    Feb 15, 2007
    15,278
    +6,020
    A fairly new combi boiler, the previous occupents had central heating put in the house - I suspect it was storage heaters previously.
  4. dazzafact
    dazzafact
    Jan 9, 2005
    743
    +81
    Never heard the term "water hammer" before, but you could have some air stuck in the system. Try on the scewfix forum for advice, they're normally really helpful. But a system drain should do the trick. But I ain't no boiler engineer if it breaks and floods your house.:D
  5. Dancook
    Dancook
    Feb 15, 2007
    15,278
    +6,020
    Hit it with a hammer you say?
    Thanks I've posted in the screwfix forum.
  6. RichardK
    RichardK
    Jan 3, 2006
    370
    28
    +81
    A few years ago I had the same problem with my bath taps. The plumber put a thicker washer on, and that solved the problem.
  7. deaf cat
    deaf cat
    Feb 9, 2005
    1,224
    48
    +58
    Sounds like the water is heating up too much too quickly, like kettling I guess, is it pretty hot when it's spluttering ?
    With the tap full on you have a lot more water passing the heat exchanger so, it's not getting so hot so quickly, no kettling, no sputtering.
    Could try turning down the hot water thermostat on the boiler and see if it makes any difference...
