Another physics question !!!!!
jenic
Man i hate this subject soooooo much, i cant get AS so what look will i have if i carry on. Anyway this is a simple one, which formula links force, speed and power?
fortean
Is this what you're after...
force = mass x acceleration
It's just that force and power seem to be the same thing.
jenic
Nope, i'll give you the question:
how much power must be generated to maintain a steady speed of 8m/s against resisting forces of 30N
fortean
Well 1 Joule = 1 Newton Meter so you need 30 Joules to move it for 1 Meter.
brendan_dj
30N of power is needed.
A body will continue travelling at a constant speed unless acted upon by another force.
fortean
For every second you would move it 8 Meters so that means every second you use up 240 Joules or 240 Watts
Chox1988
If you are being pushed with a force of 30N backwards, if you apply a force of 30N forwards you stay still, you wouldn't be at a speed of 1m/s, because the forces are equal. Forward force would have to be larger than the backward force to be moving forward.
Correct me if thats wrong but im still thinking about how to go about the answer.
fortean
That's if you were not moving to start with but if you are already moving then you just need to maintain the balance in the forces. Any inbalance will cause you to slow down or go faster.
Chox1988
yeh fair enough, i stand corrected.
brendan_dj
The question was regarding "maintaining a steady speed of.."
not "accelerate to 8m/s from stationary" So the only force required is the force needed to balance the 30N friction force working in the opposite direction.
