Another PHD8 connection Dillemma
Discussion in 'Plasma TVs Forum' started by tjradiohead, Oct 19, 2005.
  1. tjradiohead
    tjradiohead
    Jul 29, 2005
    4,036
    71
    +58
    My PHD8 should be arriving in the next two days, and although i should have worked this out by now, im still thinking about connecting my PC up, this is how i plan to have everything connected:
    i have ordered a component board which will connect my DVD player
    through VGA i would like to connect my PC
    Sky will be via Svideo for now...
    My Graphics card has DVI out and VGA out, however i dont really want to buy a DVI card for the PHD8, but my PC monitor ONLY has VGA in.
    Would i be able to connect the plasma via VGA lead and my PC monitor via a DVI - VGA lead? Will this result in PQ difficulties on my PC monitor?
  2. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    should be fine for the PC monitor, im pretty sure DVI outputs on PC cards can output analogue as well :)
    you could cancel the component, and input this to the VGA, then buy a DVI board instead? I dont know whether the DVI board is for PC use (VGA/XGAetc) or video use (1280x720p/1920x1080i etc) or both, anyone?
  3. tjradiohead
    tjradiohead
    Jul 29, 2005
    4,036
    71
    +58
    While we are (almost) on the subject of PCs...
    Can anyone reccomend a silent PSU? mine sounds awful.
