Another pc on plasma question
Discussion in 'Desktop & Laptop Computers Forum' started by dazzer123, Jan 9, 2005.
  1. dazzer123
    dazzer123
    Sep 30, 2002
    400
    Stoke-On-Trent
    +3
    Hi just built a barebones system on a budget spec is as follows
    Epox EX5300NR Case
    AMD Barton 3200+
    512Mb Geil value select dual channel
    Asus Ati 9550 with tv out
    installed windows xp hooked up to plasma via svid tvout from Asus 9550 and desktop did not fill the screen nor did dvd playback using power dvd i have a Panny 4 clone plasma 852x480 pixels should i install powerstrip and set the res as close as possible to the plasma will this cure it.
    The plasma is a starting point as i really want to get 720p via dvi to my Panasonic AE500 at a later point when i get a long enough dvi cable but want to sort out pic on plasma first would it be better if i connected pc to plasma via vga to rgbhv in on plasma any ideas please help a total noob.
