Another Panny 6 question
Discussion in 'Plasma TVs Forum' started by CARLOS, Jan 10, 2004.
  1. CARLOS
    CARLOS
    Feb 11, 2001
    6,408
    WEST MIDLANDS
    +1,403
    Firstly is the VGA input still active when you connect a TUPTA600 tuner ?
    Also is anyone using a series 6 with a tuner, If so do you lose all the picture adjustments you get when not using it, IE:Gamma, etc ?
    And do you also lose the Pic in Pic options ?
  2. CARLOS
    CARLOS
    Feb 11, 2001
    6,408
    WEST MIDLANDS
    +1,403
    Anyone :(
  3. john R1
    john R1
    Nov 2, 2002
    692
    16
    essex
    not sure about vga or pic in pic, but if its the same as the pw5 you loose most of the picture adjustments & the screen saver settings hope this helps
  4. CARLOS
    CARLOS
    Feb 11, 2001
    6,408
    WEST MIDLANDS
    +1,403
    As i thought, Thanks for the reply
