Another NUBEE - Wall Plate interconnect question
Discussion in 'Cables & Switches' started by ivanmurray, Aug 3, 2004.
  1. ivanmurray
    ivanmurray
    Jul 26, 2004
    13
    hi - I am currently doing a home self build and I am trying to design the cabelling system for my house. I have great ideas of what I want, and In the past few months i have been trying to educate myself on the do's/don'ts of installing a distributed AV system. However, I am stumped on what I believe should be a simple question for this Forum. I what to make the install as neat as possible, so I am planning on installing wall plate interconnects for the speakers in each room. I will have seven speaker systems in 2 rooms, so I am talking 7 interconnects in the rooms. My question is in relation to the Home room (the room with all the AV equipment). I also was thinking of installing the wall plates interconnects for the speakers in this room near the system location. So not to make things to complicated, there will 2 different interconnects between the Receiver and Speaker (if you do not count the interconnect on the receiver and speaker themselves).
    Questions:
    If I use this wall plate configuration will I loose Sound/Picture quality throught the interconnects?
    Is there any neat alternatives to the wall plate interconnects?
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    look at extrons range of architectural finishes and also QED some very neatplates depending on what you need, QED WM11 i think are the jobs!
