another newbie stupid question
Discussion in 'Plasma TVs Forum' started by tabs, Apr 25, 2005.
  1. tabs
    tabs
    Apr 3, 2005
    1,926
    warks
    +129
    if i was to go with component connections from an x-box, DVD player and gamecube to an LG plasma, how do you connect 3 or 4 devices into the one set of connections on the tv ? :lease:
  2. Mep
    Mep
    Dec 25, 2004
    9,603
    Surrey
    +475
    you can get a component switcher.....various components in and one set out to the screen...js do one..you can also get cheapies from whitedog
  3. tabs
    tabs
    Apr 3, 2005
    1,926
    warks
    +129
    thanks mep :smashin:
