Another newbie question: digital sampling rate
Discussion in 'Desktop & Laptop Computers Forum' started by nickc, Feb 7, 2003.
  1. nickc
    nickc
    Oct 31, 2002
    33
    The Audigy lets you choose the Digital output sampling rate,
    44.1khz
    48khz
    96khz
    What setting is best for stereo mp3/wma files?
    The card is connected to an av receiver using the coax digital input.
    any info appreciated:)
  2. Squirrel God
    Squirrel God
    The higher the better, but 44.1 KHz is CD-quality so higher could be construed as overkill. 44.1 KHz should be satisfactory for MP3s/WMAs.
  3. timothyw
    timothyw
    May 14, 2002
    519
    London W2
    +29
    Ideally you should match the output sample rate to the input MP3, which will typically be 44.1khz. There is some anecdotal evidence that people prefer higher sample rates; however before you even consider this you should ensure that your multimedia settings have sample rate conversion set to 'best', which is not the default. You could even consider using a player that uses the high quality SSRC resampler; you can obtain a plugin to do this in winamp, or you could try Foobar2000 which is officially the mp3 player for audiophiles :D.
