Another new diy build
Discussion in 'DIY Speaker & Subwoofer Building' started by ewizzy, Mar 5, 2013.
  1. ewizzy
    ewizzy
    Feb 24, 2012
    1,440
    St Ives
    +391
    So, I'm building a new subwoofer.
    It's going to be built around an audiobahn aw150t 15" driver. The driver arrived about 50 mins ago.
    This weekend, I'll hopefully start making a cut list, then possibly start the box.
    I'll post some pictures of the build ASAP.
  2. echosat
    echosat
    Feb 13, 2005
    843
    46
    staffs
    +181
    Cool there's gonna be some builds ongoing love it!
  3. scottthehat
    scottthehat
    Jan 6, 2012
    11,160
    2
    167
    honiton
    +2,801
    look forward to your build and your opionion.
  4. The Eggman72
    The Eggman72
    Nov 2, 2008
    1,914
    Hull East Yorkshire Gods own country
    +172
    Was looking at an audiobahn to replace a knackered driver in a Rel Q50 I use on my rear channels..would one do the job ?? and what kinda results ?
  5. scottthehat
    scottthehat
    Jan 6, 2012
    11,160
    2
    167
    honiton
    +2,801
    Im sure the audiobahn will do a great job even with little power, just make sure you get the right ohm driver.
    if its 4ohm look at the aw150t.
  6. M87NER
    M87NER
    Jan 12, 2010
    657
    28
    +40
    All the best with your build, make sure you take plenty of pictures :)
    are the AW150T single or dual 4 ohm? i was tempted to get for of them at first as they would match my 18" Audiobahn in looks,
    i've just ordered 2 of my 4 Audiobahn subwoofers - should be with me friday for my build which is a few months away yet.
  7. ewizzy
    ewizzy
    Feb 24, 2012
    1,440
    St Ives
    +391
    Mine is single 4ohm. Works perfectly for what I need.
    I shall be starting on my cab this weekend hopefully. The pictures will be flowing ;)
    Good luck with your build too!!
  8. skronk
    skronk
    Jan 7, 2010
    484
    28
    +43
    Good luck with your build.
    Total enjoyment.
    Keep the camera charged ?:):)
  9. ewizzy
    ewizzy
    Feb 24, 2012
    1,440
    St Ives
    +391
    I'll have my phone with me so will take pics as I go
    Alex
  10. ewizzy
    ewizzy
    Feb 24, 2012
    1,440
    St Ives
    +391
    Started on the front baffle today.
    The front is going to be gloss black
    Rest will either be clad in 6mm ply, or veneered. Haven't decided on that bit yet.
    Hope you like the photos
    Alex
  11. ewizzy
    ewizzy
    Feb 24, 2012
    1,440
    St Ives
    +391
    I may have a little help from the old man, my hands aren't that old and wrinkly... Yet ;)
  12. skronk
    skronk
    Jan 7, 2010
    484
    28
    +43
    Don't worry, it won't be long......it creeps up on you !
    Pics look good !
    Best of luck.....keep the pictures up.
  13. ewizzy
    ewizzy
    Feb 24, 2012
    1,440
    St Ives
    +391
    There's points available if anyone can correctly guess all the cars makes and models in the background too ;)
  14. echosat
    echosat
    Feb 13, 2005
    843
    46
    staffs
    +181
    Looking good bro not got a clue with the cars though
  15. scottthehat
    scottthehat
    Jan 6, 2012
    11,160
    2
    167
    honiton
    +2,801
    is one a jag and the other a rover.
  16. ewizzy
    ewizzy
    Feb 24, 2012
    1,440
    St Ives
    +391
    One of them is a jag, no rover though.
    The jaguar is an xk120
    There is a Maserati Indy, and a Daimler consort
    Good try though :)
  17. ewizzy
    ewizzy
    Feb 24, 2012
    1,440
    St Ives
    +391
    :( not happy!!!
    My behringer amp (nu1000) has died. Keeps popping fuses. Was not even on 1/4 gain.
    Unfortunately, I replaced the fan with a quiet one. I'm assuming the warranty will be void because I've opened the case? Anyone know? Has anyone tried returning a behringer that's been opened?
    Looks like I'm going to have to stump the cash for another new amp. I think I'm going to get the 400w amp from the bk xxls 400. Bk sell them for £177 including post.
    Bugger.
  18. scottthehat
    scottthehat
    Jan 6, 2012
    11,160
    2
    167
    honiton
    +2,801
    Does it pop fuses straight away.
    How old is it. Have you tried another lead.
  19. M87NER
    M87NER
    Jan 12, 2010
    657
    28
    +40
    What fuse is it popping? the internal or the one on the kettle lead,
    if in the kettle lead is it a 13amp fuse fitted?
    internal fuses normally blow when wires touch on speaker wires.
  20. skronk
    skronk
    Jan 7, 2010
    484
    28
    +43
    If you can get the amp for that money then take it. I bought the smaller 250w amp from them at £162 (I think) and with the Peerless xls12 it would blow your head off. Gain set to 12 o'clock. Very happy with it and beautifully put together.
    Good luck.
  21. ewizzy
    ewizzy
    Feb 24, 2012
    1,440
    St Ives
    +391
    It's popping the internal fuse, no speaker wires touching.
    I spoke to amazon last night, that's where I got it from. They are sending a replacement out, no questions asked!! Brilliant service.
    I may still get the amp from bk. I'll see how the 2nd nu1000 fares.
  22. scottthehat
    scottthehat
    Jan 6, 2012
    11,160
    2
    167
    honiton
    +2,801
    That's great service and just means changing the fan over again.
  23. ewizzy
    ewizzy
    Feb 24, 2012
    1,440
    St Ives
    +391
    Yeah, brilliant service!! Especially as I didn't even contact them until 9:30pm last night!!
    I may not bother changing the fan over. If I keep the amp, I'll leave the original fan in, I'm putting the amp in the under stairs cupboard anyway, so I won't hear it.
    I'll probably sell the new unopened one on eBay though.
  24. scottthehat
    scottthehat
    Jan 6, 2012
    11,160
    2
    167
    honiton
    +2,801
    if your not gonna hear it leave it as it is for sure.
    I only changed mine because it sits about 4 foot from the nearest person and the fan i have now can not be heard at all.
  25. M87NER
    M87NER
    Jan 12, 2010
    657
    28
    +40
    Can never fault Amazon customer service, we always get replacements/refunded straight away, do you not have to send the faulty one back though?
    glad you got it sorted anyway,
    Build is looking good aswell,
  26. ewizzy
    ewizzy
    Feb 24, 2012
    1,440
    St Ives
    +391
    Scott - I changed the fan as I was going to have it in my cab under the tv. I've changed that to now be in the cupboard.
    M87NER - I've never had to send anything back to amazon, but I'm really impressed. I have to send the faulty one back within 30 days.
    Thanks for the comments. I'll keep the post updated with pics :)
  27. ewizzy
    ewizzy
    Feb 24, 2012
    1,440
    St Ives
    +391
    A few more photos.
    The piece I've made this evening is really just a template for the top and bottom. I thought I would put it together just to see how big it will be.
    Will hopefully get the top and bottom cut tomorrow, back plate too.
  28. scottthehat
    scottthehat
    Jan 6, 2012
    11,160
    2
    167
    honiton
    +2,801
    looking forward to this.
  29. M87NER
    M87NER
    Jan 12, 2010
    657
    28
    +40
    Looking Very Nice,
    Looks like a similar shape to them JBL HT subs, - not sure whet they are called.
  30. echosat
    echosat
    Feb 13, 2005
    843
    46
    staffs
    +181
    :cool::cool::cool::cool::cool::cool:
